prop options
Old 04-29-2010 | 06:07 PM
Default prop options
i took some 5blade p5's off of my 31 and put bravo 4blades on. ive been very happy running fast nice control etc but, i just noticed 2 cracked ears so before i purchase something that doesnt work i figured i would see what everyone has luck with. current setup.. imco 1:26 drives 34p bravos turned IN. has anyone run cleavers? 5 blades? etc etc thanks everyone
seanv is offline
Old 05-22-2010 | 11:05 AM
Rottiguy's Avatar
Why didnt you like the 5 blades? I just added 2' shorties. Havent run it yet though.
Rottiguy is offline
Old 05-24-2010 | 10:19 PM
i thought they were the cause of some issues i was having. what props you going to run?
seanv is offline
Old 05-25-2010 | 10:12 AM
tssteph's Avatar
I have bravo props on mine. I have never tried anything else.
tssteph is offline
Old 05-31-2010 | 05:58 PM
Rottiguy's Avatar
ran mine last weekend hops out of the water at 110. Guess I need to find some boxes. Prop shaft is even with bottom of boat. would not come on plane without someone running to the front of the boat. Over all pretty happy till I blew a motor.
Rottiguy is offline
Old 05-31-2010 | 08:09 PM
Ran-Dom 32's Avatar
why do you think you need boxes? to solve your plaining issues? I have the same set up, running same speed, I had the props worked by Bblades & it carries the bow much better, planes without issue, & the hop cleans up after 90, running 34P labbed bravos & the tips have allot of cup in them
Ran-Dom 32 is offline
Old 05-31-2010 | 08:39 PM
Rottiguy's Avatar
I hopped to 110 then started blowing the props out. I had to pull the motors so I figured if I'm going to do boxes now is the time. Also wont the boxes help with the hop?
Rottiguy is offline
Old 05-31-2010 | 09:11 PM
Ran-Dom 32's Avatar
not that I'm aware of, once my boat hits 100 it runs flat as can be, no boxes, x even with bottom
Old 05-31-2010 | 09:20 PM
i have stellings boxes on mine,i cruise at 70 with no porpusing,it will hop a little between 70 to 90,above 90,its as smooth as silk,right now i have a pair of 5 blade maximus,30p,but i need more prop,looking for bravo1 34 p or 32 p to try,anybody near chicago with a pair that i can try.
mike tkach is offline
Old 05-31-2010 | 09:46 PM
Rottiguy's Avatar
with the standard lowers I would hop at 95-100 then as smooth as can be.
Rottiguy is offline
