fuel pressure gauge install >
Old 05-04-2010 | 07:11 AM
Default fuel pressure gauge install
how do i install fuel pressure gauge at the dash,my question is how or where does the sending unit go on a 502 mpi,do i t into the shrader valve?thanks
captain commando is offline
Old 05-04-2010 | 07:59 AM
Ted G's Avatar
Ideally you should remove the schrader valve and thread the sender into that port. You can also get a "T" to go between the flared fuel hose and the rail with a small piece of tubing . I have also seen people drill and tap a new hole with pipe threading right in the rail.
www.cbpba.com
Ted G is offline
Old 05-04-2010 | 11:06 AM
taking the scrader out and using that port is the easiest way i believe . but having said that, i wouldn't put the sender straight into the log. i would use a short length of proper hi press hose (not stainless teflon aeroquip ) w/ the appropriate fittings to act as a vibration damper between the motor and the sender. they are fragile little bastards and rigidly mounting them is a good path to early failure , unreliable readings as well as the possibility of leaks . i ran a length of -4 push lock such that i could soft mount the sender on the rear bulkhead
stevesxm is offline
Old 05-04-2010 | 07:05 PM
thanks,havnt bought the parts yet but this is the imfo i need to get started ,great help
