Are propshaft threads repairable? >
Old 05-04-2010 | 12:47 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Are propshaft threads repairable?
If you have had any experience with damaged threads on a propshaft, please take a look at this thread:
http://www.offshoreonly.com/forums/d...ml#post3101794
I could use the input before I move forward.
Thanks in advance.
Sydwayz is offline
Old 05-04-2010 | 01:13 PM
HotPursuit's Avatar
Should be,some things should be left to a machine shop!
Post some pics.
HotPursuit is offline
Old 05-04-2010 | 01:16 PM
Mbam's Avatar
Offshoreonly Advertiser
Brian, Snapon makes a thread chaser that you can put on the good portion of the shaft and thread off. It clamps on and has interchangable cutters.
Mbam is offline
Old 05-04-2010 | 01:18 PM
Mbam's Avatar
Or - as Hotpursuit says bring it to a machine shop. If you want to send it down here we can clean it up for you.
Mbam is offline
Old 05-04-2010 | 01:47 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thank you Marc. I am sending you an email.
Sydwayz is offline
Old 05-04-2010 | 01:55 PM
LapseofReason's Avatar
I can fix it., can you bring it by my work.
LapseofReason is offline
Old 05-04-2010 | 02:12 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thank you Greg! I may do that next week. I will call you if so.
Sydwayz is offline
Old 05-04-2010 | 02:19 PM
Should be able to do it in just a few minutes if it can be done. Sounds like a chaser or thread file and you will be good as new, I do it all the time here with axles, cranks, steering stems, so I am sure I have the tools needed. I am here M-F 9ish to 7ish you still have my cell # ?
Old 05-04-2010 | 10:29 PM
Strip Poker 388's Avatar
Rob
Id like to see a pick for future referance.
I had a buddy on a vert shaft threads that were messed up he just took a file to it, I would of screwed it up If i did that
Strip Poker 388 is offline
