yellow gas stain on white gel? >
Old 05-06-2010 | 06:15 PM
Default yellow gas stain on white gel?
Fuel out of the vent got on the boat today. The yellow stain is not coming off with soap and water.
What works?
chad1 is offline
Old 05-06-2010 | 08:54 PM
Gladhe8er's Avatar
Hull and Bottom Cleaner by Mary Kate. Don't inhale or touch the stuff though.
Gladhe8er is offline
Old 05-06-2010 | 09:04 PM
is there a non acid base cleaner that works..anyone tried CLR?
chad1 is offline
Old 05-06-2010 | 09:23 PM
seafordguy's Avatar
Might fade pretty quickly in the sun.
seafordguy is offline
Old 05-06-2010 | 09:55 PM
Try toilet bowl cleaner. If that doesn't work...sand/or compound and buff.
Jay
us1kw is offline
Old 05-06-2010 | 10:29 PM
thanks
chad1 is offline
Old 05-06-2010 | 11:14 PM
I would just use some buffing compound and elbow grease. Some of those chemicals can really destroy paint, gel, or even the fiberglass. If you really feel the need to use a house hold cleaner, try acetic acid (vinegar). You could also use some Soft Scrub. That stuff works well.
Planetwarmer is offline
Old 05-07-2010 | 12:33 AM
Try some Clorox Clean Up. It cuts grease and will bleach out stains. Acids generally don't work on greasy or petroleum based stains.
Griff is offline
Old 05-16-2010 | 11:45 PM
one time as I drove up to get fuel at a dock they had a gas spill.. it made a yellow glue slime on the hull. Industrial acetone worked perfectly. It also stripped off all wax but worked perfectly. Key word industrial strength
relaxalot is offline
Old 05-17-2010 | 06:53 AM
Indy's Avatar
Member #154
Agreed...I used it many times on my PowerPlay and Nordic, no issues, works great. Don't think I'd be too crazy to get it on my paint tho. I just used a disposable brush to apply it, hose it off a few minutes later.
Indy is offline
