CONTEST:Guess my Engine Dyno HP & WIN an Engine Alignment Tool >
Old 05-08-2010 | 07:18 PM
Default CONTEST:Guess my Engine Dyno HP & WIN an Engine Alignment Tool
Gellner Engineering is just about done building my engine and should be going on the dyno Tues (May, 11th).
I figured I would run a little contest(hope this works).
Throw out your peak HP number FIRST in your response(easier to go thru afterwards) or you will not be counted. I will take numbers till the results are in, one number each please.
Closest WITHOUT going over will win a new Bravo/Alpha engine Alignment Tool and I will pay for the shipping to(USA 48 states only). For a tie I have a fair tiebreaker idea if needed.
Hint: This engine build was just to put a reliable engine together and nothing crazy like some of you guys have.
Here is the engine stats:
547 CI stroker engine.
Naturally aspirated
10-1 Compression
World Merlin aluminum heads, bowls pocket ported.
850 Holley carb
Team G hi rise intake(no port matching)
Crane 741 cam Hydraulic roller/roller rockers lift Exh:632/Int:610
Stock thunderbolt ignition
Good Luck
My cheap plug= If anybody is looking for a Alignment tool or Gimbal bearing remover/installer or other tools Check me out on Ebay: whoya2350
whoya is offline
Old 05-08-2010 | 07:29 PM
625 hp @ 5500 rpm
HALLETT FAN is offline
Old 05-08-2010 | 07:32 PM
scottw's Avatar
650hp
scottw is offline
Old 05-08-2010 | 07:36 PM
What correction factor?
thumper038 is offline
Old 05-08-2010 | 07:53 PM
Rookie's Avatar
With or with out accessories??
Rookie is offline
Old 05-08-2010 | 07:56 PM
630 Hp @ 5500 Rpm
BenPerfected is offline
Old 05-08-2010 | 08:00 PM
With seawater pump and I think he said with Alternator to.
whoya is offline
Old 05-08-2010 | 08:04 PM
WeaponX's Avatar
Good one.
WeaponX is offline
Old 05-08-2010 | 08:14 PM
Panther's Avatar
Frank's Marine Service
675hp @ around 5800
Panther is offline
Old 05-08-2010 | 08:23 PM
640hp
teamsynergy is offline
