502 rebuild
Old 05-09-2010 | 07:42 AM
Default 502 rebuild
Do the mains have the same torque 110 ft/lbs, even though different length bolts? whats the best lube on the threads? thanks
Brushwolf243 is offline
Old 05-09-2010 | 09:14 AM
Ted G's Avatar
Yes. all bolts have the same torque. You can use assembly lube or motor oil on the threads.
www.cbpba.com
Ted G is offline
Old 05-09-2010 | 09:34 AM
What about the heads? Whats the torgue on them?
Old 05-09-2010 | 11:16 AM
The mains torque to 110 with 30 wt motor oil. If you use a moly lube then the torque spec will change. The moly has much less friction, so it will use a much lower torque spec. I don't know what it is. I always use oil and 110.
Torque the heads to 75 ft lbs. Do it in 4 stages.....30, 50, 65, 75 ft lbs from the center out.
Eddie
Young Performance is offline
