Set Screw Removal
Old 05-10-2010 | 02:19 PM
Default Set Screw Removal
I am replacing my Q-jet with a 850 holley but cant get the set screws out of the intake for the holley bolt pattern. Any ideas how to remove these bastards??? I have used heat and bent 3 allens and broke one scocket/allen set up. One came out but the other 3 won't budge. Any one have this issue if so what did you do to remove thiem. Thanks in advance.
Justin
pachanga27 is offline
Old 05-11-2010 | 02:10 AM
They must be seized in. You will probably have to drill them out most of the way. Use left handed rotation drill bits.
Griff is offline
Old 05-11-2010 | 09:09 AM
Thanks Griff I'll give that a shot!
Old 05-11-2010 | 09:35 AM
More heat
I just had to take out several that where stuck exactly like yours. One was an oil galley plug in an brand new engine that I could not use a drill on, so I used gas welder to get it hot enought to come out. Others I used propane torch and just held it on for along time. They all came out with no problems.
1BIGJIM is offline
Old 05-11-2010 | 03:46 PM
JasonSmith's Avatar
Just buy a new intake & save yourself a ton of hassle & gain some performance while you're at it.
I tried to do the same thing you're trying to do years ago & I just decided to spend $300 & get some new sh!t.
JasonSmith is offline
Old 05-11-2010 | 04:36 PM
Default Fixx
warm up the intake stud with a propane torch and tap the stud top with a hammer,,also if you take some candle wax while the stud is still warm it may penetrate the threads in the intake so they can be removed..
FIXX is offline
Old 05-11-2010 | 05:33 PM
Strip Poker 388's Avatar
Rob
they say the candle wax works
Strip Poker 388 is offline
Old 05-11-2010 | 08:48 PM
Cool thanks for all the replies. Not buying a new intake just picked the motor up from the machine shop.
Old 05-12-2010 | 07:04 AM
Airpacker's Avatar
If its an aluminum intake, go to the drug store and buy a bottle of tincture of iodine. Soak the screws repeatedly for a day and for some reason, it will eat away at the aluminum oxide that is acting like loc tite and allow removal of the screws. Age old trick to release things frozen in aluminum.
We use it regularily to loosen aluminum A/C fittings, alternator case bolts etc. Not fast but it works without taking the threads with it.
Airpacker is offline
