Depth Finder Wire
i would think so just like any wire that gets cuts, and if you need more wire, find the like gauge. Instead of just splicing wires together its always better to put each end into a connector then connect i always like tapping over it too.
i think the outside mesh wire is just a shielding vs conducting anything, you can probably find some and re attach or attach attach the wire without the shielding you might need it. That shielding is either for heat or to block intereference. If not youll be stringing together a new wire
