Correct Timing Module for carb 5 HP-500 >
Old 04-26-2002 | 01:47 AM
Default Correct Timing Module for carb 5 HP-500
Looking for timing specs and the proper module number for carbed HP-500's with Thunderbolt-4 ignition. It appears there may be 2 diff modules in now with diff curves, but same total advance.
Help would be greatly appreciated.
CCPerformance is offline
Old 04-26-2002 | 04:32 AM
If you got to www.mercruiserparts.com you can look up the engine by serial # and check to which module was used on it. I think it should be the HP module with 20* of advance.
Griff is offline
Old 04-26-2002 | 10:12 AM
Default HP-500 Timing
These are re-man'ed engines so there are no serial numbers. They're Gen- 5 which pust them at about 90-95 vintage with Thubderbolt 4 ignition..
Old 04-26-2002 | 10:27 AM
ursus
The TB IV ignition amp for the gen V HP500 merc part # 17316A1
is different then the TB IV ignition amp for the gen V 454/502 merc part #15248A1
Also the really early Gen V TB IV HP500 used 17316A2 but this was more like a big square box looks like a crane cap discharge thing , dif than the standard merc ignition amp on the triangular plate
Old 04-26-2002 | 10:31 AM
Hey Ursus:
This is teh smaller type unit. So I assuming this woudl be the 17316A1? Any idea what the specs are?
Old 04-26-2002 | 11:18 AM
There are seven different modules available from Merc with advances that range from 14 deg. (used stock in V-6's but sometimes also in extreme hi-perf V-8's with idling problems) to 24 deg. The part you mention has a 20 deg. adv. With that one you would set the initial timing at 14 deg. adv to give you 34 deg. final at 3000 rpm. All pt.#'s and detailed info in Dennis Moore's "BIG BLOCK CHEVY MARINE PERFORMANCE" Hope this helps more than it confuses. --- Jer
jpclear is offline
tssteph
2
07-24-2008 07:49 AM
tomcei
11
09-13-2007 10:57 AM
Gary Anderson
10
05-24-2004 09:43 AM
Mr. Demeanor
4
09-18-2003 08:10 PM
