slave solenoid
HI all. i need several turn key before the starter go on on my 496 HO,wen i turn key i eard a little clic thats all.first i think i have to look at the slave solenoid but i cant find it.any help.thank
check all the main battery cables first for cleanliness and tightness....it's usually the simple stuff....then the ignition switch, then try the slave, worst case..an ignition module...at least that's the way my 350's behave....
I have the same problem...
Had the starter bench tested, cleaned, and new solonoid...not fixed.
New battery...not fixed.
Slave solonoid (I could not find it at first either, one member posted on my question some photo's, that helped big time!)
Mine is a 454 magnum and is located under a plastic shield beside the anti corrosion blue box.
I assume continuity?
