Head bolts or studs >
Head bolts or studs
Head bolts or studs
Old 05-18-2010 | 09:54 AM
Default Head bolts or studs
If cost isn't an issue would you use studs?
I have read mixed opinions, with even one person saying they didn't like using studs because they tend to leak (MKIV Block).
I think the only reason I'm leaning towards studs is the finer thread for the nut. It makes me think I'll get a more accurate torque... that and I'm somehow swayed by a perceived cool factor.
jackhammer is offline
Old 05-18-2010 | 02:03 PM
mostly stock type motor I would just use head bolts
anything with aluminum heads or making a good amount of power over 650 hp I would go with head studs
cbellamore is offline
Old 05-18-2010 | 02:11 PM
Ditto. Use some ARP thread sealer on the studs if you use them.
Griff is offline
Old 05-18-2010 | 02:40 PM
Thanks guys... 550hp with iron heads. Looks like I'll get the bolts and show the wife how much money I saved!!
