Here's my latest project >
Old 04-26-2002 | 06:25 PM
26scarab's Avatar
Default Here's my latest project
Well it should be done this weekend
Hopefully this should be worth something, if not it will look cool !
26scarab is offline
Old 04-26-2002 | 08:10 PM
MIKEHTMSR24's Avatar
Default is this the one i
sold you?
MIKEHTMSR24 is offline
Old 04-26-2002 | 10:56 PM
Why the upward hook to the cone.
maybe a bad pic
please explane
scottf1-57 is offline
Old 04-27-2002 | 12:03 AM
Tinkerer's Avatar
Cool
I just got my IMCO shortie lowers and they look a lot like that without the camo paint.
Tinkerer is offline
Old 04-27-2002 | 05:18 PM
supercrash
Looks great 26..very smooth..
scott the hook looks like a illusion..maybe a sliver of shadow underneath....?
Old 04-27-2002 | 06:32 PM
Very nice
Gearhead99 is offline
Old 04-28-2002 | 07:45 PM
26scarab's Avatar
Mike, Yes that is the one I bought from you.
The hook must be an illusion.
i think it is an Imco cone, the hydromotives have a different shape. I finished painting it this weekend , now I just have to put it back together and finish the Upper.
Thanks , for the replies
26scarab is offline
Old 04-28-2002 | 07:47 PM
Default IF
you hook up the inside speedo let me know how it worked out
Old 04-28-2002 | 08:08 PM
Chuck; What did you use for filler on that drive?? We took my trs's done to bare aluminum, to try to get most of the pits out but it would be real nice if we could fill whats left. I was told that nothing will stay for very long.
Has anyone else had good luck with filler??
delsol is offline
Old 04-28-2002 | 08:53 PM
26scarab's Avatar
Mike,
Unfortunatly the guy that welded the cone on mistakenly welded up the speedo hole. I had asked him just to weld the low water pick-up hole and he did both That was the reason I bought yours , it had the speedo. And now that its done I should have left the low water pick hole open , then I could have tapped into the top of the cone and use that as a drive cooler pickup.
Delsol,
After i had the cone welded, i use Miller-Stevenson 2 part epoxy and filled it as much as possible. Then i just used regular automotive Bondo. I then painted it with a self etching primer and finished it with some black paint.
Hopefully the Bondo will stay a while.
26scarab is offline
MESABALANCING
1
06-11-2005 09:18 AM
thunderusone
02-21-2005 08:53 AM
Madcow
11-03-2002 05:22 PM
glassdave
10-10-2002 10:43 AM
