Help - Getting engine hatch open with no power >
Old 05-22-2010 | 11:13 PM
Default Help - Getting engine hatch open with no power
I have a 30 foot formula that I need to get the engine hatch open, but the batteries are drained. I have plugged in the shore power but nothing is getting power as far as I know. This boat is new to me and I just picked it up last fall and put it in storage. The storage facility was supposed to trickle charge the batteries, but probably tried to do this to late. Any help would be appreciated.
Snoworks is offline
Old 05-22-2010 | 11:29 PM
Ebay Ed's Avatar
on my baja there are jumper post under the rear bench seat for the batteries i would guess that there are some on yours someplace
Ebay Ed is offline
Old 05-22-2010 | 11:38 PM
Hook a wire to a good battery and then hook it to back of the hatch switch on the dash.
Griff is offline
Old 05-23-2010 | 12:04 AM
Thanks for the replies, I found the jumper switch.
Its supposed to be 87 tomorrow in lower Wisconsin so I want to try and get this out on the water!
Snoworks is offline
Old 05-23-2010 | 09:32 AM
Default easy
just lift the hatch part way by hand. Look under it you should see the lift ram. Have a friend pull the pin out of the lift ram. Then use something to prop the hatch up the rest of the way.
code blue is offline
Old 05-23-2010 | 03:59 PM
mpally's Avatar
Not all older boats have this system.
mpally is offline
