Bravo1 VS Hydromotive
the hydromotive has welded blades and is faster, also real size stamped.
The bravo I is cast and is usually 1-2 sizes in pitch smaller then stamped also thicker blades and heavyer ( slower ) !
Hope that helps.
Hope that helps.
So a 28" Bravo 1 = a 27" Hydromotoive (model??). Julie we have been exchanging emails on my 27' Fountain with Raylar kit, wondering if a Hydro may be the way to go? I was thingking a labbed 28" Bravo would be what i beed but am unsure. Thanks Pete
I find the Q4x to be faster than the Bravo props, plus I like that they can be ordered in 1 inch increments. They slip a little more on the bottom end due to the shorter tail cone, and have about the same slip as a bravo in the middle and top end.
Chris
The P5x is a 5 bladed version of the Q4x. It works really well for those looking for more hook up than a 4 bladed prop can provide. They hook up like glue on the bottom end, and have great midrange cruise speeds and good top end.
I use a 30 P5x as my every day prop for cruising and/or pulling my kids on an innertube. On my boat, it has a little too much blade area for when I want to go really fast, and I switch over to a 31 pitch Q4x. The 4 blade seems to keep the stern setteled more and provide better handling over 90 mph on my single engined v-hull.
Chris
Chris
You can order Hydro props lab finished, and then they spin about 100-150 rpm more than their stock counterparts. What this means is that if you ordered a 28 lab P4x, it would spin about the same rpm as a non-lab 27 P4x but have greater speed at just about every rpm.
As you can see, I like these props... they work well on my boat.
But every boat is different.
Chris
