How much drive oil in the sea water/fuel pump resevoir? >
Old 05-26-2010 | 12:55 PM
Default How much drive oil in the sea water/fuel pump resevoir?
Am I to assume that it get's filled like a differential, up to the bottom of the fill plug hole? Also, what have you guys been using to help the paper gasket seal? Last time i used gasket tack, I was going to lightly coat the gasket with some black oil/fuel resistant rtv.
Ryan
cloudmaster_321 is offline
Old 05-26-2010 | 01:29 PM
Ted G's Avatar
Yes, fill to the bottom of the hole. I used Merc Perfect seal, but Hi Tack or RTV would probably work too.
www.cbpba.com
Ted G is offline
Old 05-26-2010 | 10:56 PM
What Ted said
Griff is offline
Old 05-26-2010 | 11:30 PM
Curious to what resevoir you are referring to...
Irishtornado is offline
Old 05-27-2010 | 07:37 AM
Ted G's Avatar
In the body of the Mercruiser raw water pump that also holds the mechanical fuel pump there is a chamber with a small cam to run the fuel pump arm. That chamber is about half full of oil. It should be changed at least once a year. Some people use Merc gear oil and some use 30w, either seem to work fine.
www.cbpba.com
Ted G is offline
Old 05-27-2010 | 12:33 PM
For sure want to change it at least once a year. You wouldn't believe how diluted the oil get's even after 20hrs from the fuel. New fuel pump or not, the fuel still makes it into the resevoir. I have heard of some people drilling and tapping the bottom of the pump for easier oil drains. I personally just unmount the thing and put it on my bench and change stuff there. It is only about a 15 minute job to get that pump off as long as you have room to work.
Old 05-27-2010 | 02:10 PM
BDiggity's Avatar
Do all engines require this? I have hawk 525's & going to be changing fluids this weekend.
BDiggity is offline
Old 05-27-2010 | 02:27 PM
Ted G's Avatar
If you have a mechanical fuel pump mounted on your sea water pump then you have it.
www.cbpba.com
Ted G is offline
Old 06-08-2010 | 01:52 AM
I looked at mine and see a plug to remove, but thought this was to drain the fuel that gets in there not put oil in. Do you have a picture of this? I have a Tech Manual for the 500efi and can't find any info regarding this..
Old 06-08-2010 | 06:10 AM
t500hps's Avatar
21 and 42 footers
My 2002 500efis only had the one fill hole so. I took the pumps off, drilled and tapped drain holes and now can drain and refilll right on the motor. My buddies 1998 era 500 (carbed) came with a drain already in it.
t500hps is offline
