Whipple intake manifold.....huh? >
Old 06-06-2010 | 11:37 AM
PhantomChaos's Avatar
Default Whipple intake manifold.....huh?
I am having my engines with the Whipple 3300 on them rebuilt. We had to get new intake manifolds due to some corrosion on the original intakes. Here is a pic of the new intake, and the whipple gasket. Why didn't they make the water bypass port match up with the gasket?
We were thinking about porting that but it might be too thin in that area. Not sure yet. Thoughts?
Also, there is no finish on this part besides the paint. I am suprised that they don't clear anodize the part prior to painting. Naked alluminum will eventually corrode without protection (like my last intakes did). Think I could anodize the part with the paint on it or maybe at least a chem film (irridite).
Attached Thumbnails Whipple intake manifold.....huh?-oso-whipple-dsc03218.jpg   Whipple intake manifold.....huh?-oso-whipple-dsc03220.jpg
PhantomChaos is offline
Old 06-06-2010 | 12:30 PM
CcanDo's Avatar
You may want to send your question/pictures to Dart Heads ...They claim to be proficient with their coatings.
CcanDo is offline
Old 06-07-2010 | 12:25 PM
Are intake manifolds not normally plated at all?
Old 06-07-2010 | 12:46 PM
Ted G's Avatar
The Merc aluminum ones have bronze cooling passage liners and are painted on all exterior surfaces.
www.cbpba.com
Ted G is offline
Old 06-07-2010 | 12:54 PM
I wouldnt worry about the passages lining up perfectly, Still plenty of flow thru the opening
SHAWN DAVIS is offline
Old 06-07-2010 | 10:55 PM
Yes.....but look at my last manifold. This is 5 years old. There was no protection on the bare aluminum!!!
Attached Thumbnails Whipple intake manifold.....huh?-scope-2010-springfling-18.jpg   Whipple intake manifold.....huh?-scope-2010-springfling-19.jpg   Whipple intake manifold.....huh?-scope-2010-springfling-20.jpg
Whipple intake manifold.....huh?-scope-2010-springfling-21.jpg   Whipple intake manifold.....huh?-scope-2010-springfling-23.jpg
Old 06-07-2010 | 11:33 PM
I know u can get them coated after ....i think Dart does this as well as other companys..its only like 200 bucks or so ?!
DareDevil is offline
Old 06-08-2010 | 07:18 AM
Ted G's Avatar
Is that a Whipple manifold? You may want to check with Canfield or one of the other head manufacturers. I know they hard anodize their marine heads, but you still need to flush religiously. Since that one lasted 5 years I suspect you do a good job of flushing, I had one puke in a year of brackish water. BTW, there should be Merc Perfect Seal used around all those water ports when the gasket is installed, it will help keep that from happening also.
www.cbpba.com
Ted G is offline
