Gimbal Bearing
Old 05-26-2010 | 07:32 PM
Default Gimbal Bearing
Just changed the gimbal bearing. There was no grease hole to line up. There was an indicator mark but no hole??? Did they switch to a sealed bearing? I haven't had a chance to ask the dealer where I got it.
Sunshadow is offline
Old 05-26-2010 | 07:47 PM
ChristianGott's Avatar
the ribbed sleeve around the housing slides...rotate it until you see the hole...
ChristianGott is offline
Old 05-26-2010 | 07:49 PM
I spun it around about six times never found the hole so I took it off still no hole.
Old 05-26-2010 | 08:10 PM
seafordguy's Avatar
I recall reading that the new ones aren't greaseable.
seafordguy is offline
Old 05-26-2010 | 08:26 PM
scottw's Avatar
I second that. I was told they are sealed. No grease.
scottw is offline
Old 05-26-2010 | 08:46 PM
I just installed one with no grease hole and even came with a small plug. The plug is put in place of the grease fitting..so anyway the new gimbal is a sealed unit.
Erik
crapr6 is offline
Old 05-26-2010 | 09:18 PM
t500hps's Avatar
21 and 42 footers
yep....no more hole...this way they wear out faster so have more parts to buy, more often!!!
t500hps is offline
Old 05-26-2010 | 11:21 PM
Default Fixx
just got a few from sierra today,still has the greece hole in them..new merc?? yep they quit putting the hole in them..
FIXX is offline
Old 05-27-2010 | 01:17 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I'm thinking it's a good thing. sealed bearing.....where's the grease going to go then? Nowhere. it's staying put.
I've had vehicles with over 100k miles on the sealed wheel bearings and never an issue.
I just replaced both of the greaseable bearings in my new NOS transom assemblies with sealed bearings. Never been installed, but a few yrs old sitting on the shelf. I'm ok with that.
US1 Fountain is offline
Old 05-27-2010 | 07:43 AM
yes, they call them lubed for life.....just don't say how long that life is....
ezstriper is offline
