Starter noise, but does not turn over. >
Old 05-28-2010 | 06:39 PM
Default Starter noise, but does not turn over.
Okay I am confused. I have had the engines out of my boat multiple times now and never faced this one. I rebuild my engines this winter and finished the re-installation of everything today and went to crank them over and both engines did the same thing. The starters made noise but did not engage or turn over either engine.
Here are things that I have checked.
1. I have checked and switched my grounds to make sure that I have good grounds.
2. Checked the flywheel to make sure that I did not put in on backward.
3.One brand new battery and one old just charged.
What else should I check? I can not believe that both starters have failed at the same time.
OhioRiverCigarett is offline
Old 05-28-2010 | 06:56 PM
offthefront's Avatar
could be a Voltage Issue (cable,gnd) ..if you dont get at least I believe its 9.6 Volts the Bendix wont engage ....you can check the voltage under load on the starter ...Common issue could be Ground .....m
offthefront is offline
Old 05-29-2010 | 10:36 AM
Fountain4402's Avatar
Starters are shot, forgot to put the shim in or put the shim in that you werent suppose to. That or not enough juice. Check all connections again.
Fountain4402 is offline
Old 05-29-2010 | 10:49 AM
Default USed them last year no issues
I am running MT200 high torque (3HP) starters from DB electrical. I have 3 wires (the red battery lead from batter, red feed wire to engine circuit, and orange wire to the alternator) on the large post and the yellow start wire on the spade lead.
I can hear the solenoid engage and the start turn, but it is not engaging the engine.
I will check the bendix to see if it is stuck and measure right.
And other thoughts?
Old 05-29-2010 | 02:58 PM
Scarab3DMC's Avatar
did you change the flywheels ? my starter ring was wrong when I got my motors done, the ring is @ the face of the flywheel.
Scarab3DMC is offline
Old 05-29-2010 | 03:33 PM
birdog's Avatar
Yup....Flywheels wrong
birdog is offline
Old 05-29-2010 | 04:04 PM
Steve Snider's Avatar
Default Starters
The MT200 high torque (3HP) starters from DB electrical have two sets of mouting holes to adapth for either flywheel...you most likely have 168 tooth. Check your mounting.
Steve Snider is offline
Old 06-05-2010 | 12:01 PM
Default Update
Update. The last time that I installed the starters in was in a hurry and installed them upside down. That is why both of them were not engaging.
Thanks for the help.
