Thinking about getting a performance boat. >
Old 06-03-2010 | 01:31 PM
Question Thinking about getting a performance boat.
I used to be a frequent boated with a 20 foot craft. This was 18 years ago. Think about getting back into boating and have always wanted a performance boat. I am looking at older (early 90s) Fountains in the 32 to 38 foot range. Any insight you veterans can provide would be appreciated. Specific concerns / questions:
I have a 3500 Silverado with the Duramax diesel in it, will it tow a 35 or 38 Fountain safely and legally?
How big of a PITA is it to trailer a boat that big? I have towed many car trailers and many years ago I worked in the boat business and would tow two 20 foot Ranges from the factory to the dealership but that was a long time ago and this is a different game.
How difficult are these boats to launch from and load onto a trailer?
The lake I am going to use the boat on the most only sells what they call enhanced 89 octane fuel. Will a 93 with stock 525 HP SC motors run on this?
Any particular issues to watch for on these older Fountains?
The shorter the boat the newer I can afford, are there major changes in the mid 90s through early 2000s that are strong advantages that I should consider?
Any general tips, suggestions, pearls of wisdom from experience you can provide would be great.
Thank you.
Stilwell is offline
Old 06-03-2010 | 02:05 PM
i am sure you are experienced enough towing and launching a boat like you already know it takes practice with anything new . i have had a few diffrent boats over the years and have only gotten better at operating and trailering each one . it takes me no longer than a minute to put the boat on the trailer and less to take off ( yes i do get bored and time myself ) . i love fountain boats with a passion because of how they ride , handle and are made not to mention going faster with stock power than everyone else . i would be a little scared to run not great gas in 525's but 525's are proably the best go fast motor out there when it comes to turn key and drive . i have a 93 and it has been used alot but looks and works wonderful , don't forget b o a t break out another thousand cause its true but if thats your passion who cares . where i live i see people with all diffrent sizes of boats up to 38 feet launch at public launches with out issue , if i were you i would talk to people who have larger boats where you want to use yours and ask them questions like where they launch and what not . i have no idea where you want to use this boat but for me a 27 foot is a relatively large run about which works great for windy days or weather that sucks i would love to have something bigger but checkbook is just not there yet ! lastly make sure you have someone who knows boats check out the boat and trailer before you buy and if repairs need to be made put everything in writing before hand . most trailers work really well for the size of boat they trailer if they are maintained like the brakes , bearings and tires if a trailer is in good working your truck will work well i think .
money455 is offline
Old 06-03-2010 | 02:44 PM
DollaBill's Avatar
OSO OG
FYI - only run 89 in 525's. Thats what they are designed for and run best that way
DollaBill is offline
Old 06-03-2010 | 02:47 PM
what lake and whats ur budget?
dreamer is offline
Old 06-03-2010 | 02:48 PM
Bill that is the newer 525's.........Is it the same on the older carb'd 525 SC's?
Be careful on the older carb'd motors and ethanol laced fuel. The ethanol is causing the valves to unseat or something due to heat buildup from what I remember.....
Jupiter Sunsation is offline
Old 06-03-2010 | 03:03 PM
DollaBill's Avatar
OSO OG
Thats the newer 525's Jup. The sc's are supercharged so they need the octane boost. Sorry I didnt clarify
Old 06-03-2010 | 03:32 PM
Will mainly run on Table Rock Lake in Missouri. We may also see some time on Lake of the Ozarks and a couple of the smaller lakes closer to home (KC area) for afternoon trips.
Budget, good question as I could spend a lot more than I want to. I am currently looking in the $50,000 - $70,000 range. I have found a real nice boat with 500 hours on 525 carbureted SC motors for $50,000. The boat is in excellent condition, no dock rash, kept in doors, sparkling clean engines and bilge, good interior. The color choice is not the best but if I am going to sacrifice something I would rather it be that than condition. I am going to look considerably more before buying and obviously I will lake test "the one" before any deal is made.
Thank you.
Stilwell is offline
Old 06-03-2010 | 03:35 PM
I don't know what a 38 Fountain weighs on the trailer but go here for your truck's towing specs;
http://www.offshoreonly.com/forums/t...er-thread.html
You'll need to leave more space between your rig and the vehicle ahead of you. Right turns will require wider arcs. Launching and retrieving will be different from what you're used to but you have a good strong truck for it. Getting the boat on the trailer will be easy with twin engines to counter wind and currents.
Catmando is offline
Old 06-03-2010 | 03:40 PM
can get WAY more boat than that for 50-70k
dreamer is offline
Old 06-03-2010 | 04:07 PM
DollaBill's Avatar
OSO OG
fo sho
