Cmi Etops
Old 06-08-2010 | 05:02 PM
Default Cmi Etops
Just recently installed CMI ETOPS on a 496 MAG HO. While in neutral exhaust water only comes out the starboard exhuast. I'm told by "others" that this is normal while in neutral. Can't get CMI to answer my emails. Would really appreciate any insight. Thanks!
Eddiebaja is offline
Old 06-08-2010 | 05:43 PM
Default Fixx
restrict the side the water is coming out..or you may have a weak impeller.
FIXX is offline
Old 06-08-2010 | 06:12 PM
is the water being shifted to the starboard side only?
Old 06-08-2010 | 06:35 PM
That doesnt make sense - how is the exhaust getting cooled on the side water isnt coming out.
It is not correct...
Keith Atlanta is offline
Old 06-09-2010 | 01:35 AM
+1 whoever told you it's not suppose to be coming out both sides is feeding you BS.
Irishtornado is offline
Old 06-09-2010 | 05:44 AM
LAriverratt's Avatar
agree, water can't mysteriously move to just one side with no crossover on the headers... BS on that.
LAriverratt is offline
Old 09-01-2010 | 10:14 PM
i installed a set on a customer's 277 islander and at idle in neutral i had good water flow through both pipes, definatly check the impeller also check to make sure the collecter tube hoses aren"t pinched off.
port side fit ok starboard on the other hand was a nightmare due to the cool fuel module being in the way
i had this problem while installing them ,had to make my own, so much for a bolt on kit!
outlaw 904 is offline
