Trailer sways
Old 06-13-2010 | 04:30 PM
Default Trailer sways
I replaced a tri axle steel trailer with an aluminum tandem axle trailer. The new trailer has a tendency to sway at highway speeds. Do I have too much or too little tongue weight?
raytart is offline
Old 06-13-2010 | 06:33 PM
Craney's Avatar
You need more weight on your tongue,I think it's 10% of your weight should be on the tongue.
Craney is offline
Old 06-13-2010 | 08:28 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It could be either, but probably too little.
Sydwayz is offline
Old 06-13-2010 | 10:37 PM
Set your truck up so it is sitting fairly level, not all sagged out in the back, and add more tongue weight. Most of the weight in a boat is in the rear anyways so the axles on the trailer need to be pretty far back. Check truck and trailer tire air pressure also. Good luck.
offshorexcursion is offline
Old 06-14-2010 | 06:24 AM
Audiofn's Avatar
Charter Member #232
Make sure the trailer is level as well.
Put your best foot forward!
Audiofn is offline
Old 06-14-2010 | 09:52 PM
Ray
raytart is offline
