Trailer sways
Trailer sways
I replaced a tri axle steel trailer with an aluminum tandem axle trailer. The new trailer has a tendency to sway at highway speeds. Do I have too much or too little tongue weight?
Set your truck up so it is sitting fairly level, not all sagged out in the back, and add more tongue weight. Most of the weight in a boat is in the rear anyways so the axles on the trailer need to be pretty far back. Check truck and trailer tire air pressure also. Good luck.
