Water pump shaft driven fuel pump
Need a little info on replacement fuel pump to be water pump shaft driven. where can I buy without paying mercs premium? I realize that the arm on the pump is different, are there alternatives? anyone?................................Rjr........ .......................
Thanks I found one 861677T OEM Merc for 149.00 Bam has them for 166.00 not much difference just seeing what I can find...................................Rjr........ .........................
If this is for a BBC, the OEM maker is Airtex, part number is 60932. http://www.showmetheparts.com/airtex/#
You can have autozone order you one for ~$65. It won't be painted black, but it's the same pump - been running mine for over 30 hours, bolted right up, no issues.
http://www.autozone.com/autozone/cat...&parentId=49-0
