TRS Rotation Question >
Old 06-14-2010 | 03:08 PM
Default TRS Rotation Question
While looking from the input shaft side of the TRS unit, when I turn the input shaft clock wise the prop shaft spins the exact same way (looking from the input shat side). What rotation is this?
31scarab31 is offline
Old 06-14-2010 | 04:47 PM
The engines turn ccw ( viewed from the rear), so if both shafts are turning the same direction it's the l/h rotation drive.
JaayTeee is offline
Old 06-14-2010 | 04:54 PM
Mbam's Avatar
Offshoreonly Advertiser
Exactly - also the end of the prop shaft should be stamped
Mbam is offline
Old 06-14-2010 | 07:23 PM
Yep, look for a little "R" or little "L" on the end of the propshaft. It will be stamped on the end. Kinda hard to see sometimes
MILD THUNDER is offline
Old 06-14-2010 | 09:55 PM
thanks for the information.
