Any idea where these wires go >
Old 06-15-2010 | 07:54 AM
Default Any idea where these wires go
Having a problem with wondering if these wires need to be connected..
The first two pics are the drive Lube monitor and it has two wires coming from it..do they need to be connected and if so where..i went from an MPI engine to a carb, but the engine installer did not connect them
The other two wries r coming out of the transome plate, and they r not connected either..i'm figuring that one should connect to trim guage because i'm not getting a reading on the dash as far as where my drive is..the other ? and where to connect to ?
Thanks Q
Attached Thumbnails Any idea where these wires go-latest%2520pictures%2520013.jpg   Any idea where these wires go-latest%2520pictures%2520014.jpg   Any idea where these wires go-latest%2520pictures%2520016.jpg
qaberdeen is offline
Old 06-15-2010 | 08:11 AM
Ted G's Avatar
The 2 wires from the bottle hook up to the drive lube monitor on an injected and some carbed motors. If you don't have that hook up then don't worry about it, or you could hook up your own little light or buzzer if you'd like, the contacts close when the level gets low. The 4 wires coming from the transom are trim limit and trim gauge sender wires. The trim limit will be closed when the drive is down and open when you trim it way up. The gauge sender will have changing ohms across the wires as you move the drive, you should find the wires to plug in somewhere along the stringer unless your boat doesn't have limit or gauge.
www.cbpba.com
Ted G is offline
Old 06-15-2010 | 09:05 AM
Thanks Ted, i guess i have to search around for the the wires, i guess once found, i'll try both to see which one moves the drive guage..
thanks again
Old 06-15-2010 | 10:30 AM
Ted G's Avatar
You're welcome. Is your 22 the red one that was bought from a guy in Maryland by the name of Mike?
www.cbpba.com
Ted G is offline
Old 06-15-2010 | 01:38 PM
Yeah, i recently sold it though, regretting it everyday...
Old 06-15-2010 | 01:40 PM
that return wire, i should be able to trace it from the dash right..the one that will plug into the ones above coming out of the transome plate..
Ted G's Avatar
LOL so is he
www.cbpba.com
Ted G is offline
Old 06-15-2010 | 07:13 PM
Ted..I Know..lol
Old 01-22-2011 | 02:26 PM
Can anyone tell me where the the trim sender wires plug into, these r the two black wires coming thru the trasome.. when the engine was installed looks like these wires where overlooked..drive works great now just want the electric guage to work..i've looked up n down the engine wire harness but i don't c any loose wires..so just wondering where i can plug these wires
thanks
Q
Old 01-22-2011 | 02:49 PM
thanks
Q
I "think" those plug into the trim pump solenoid....there should be bullet plugs off the trim pump that go to the bullet plugs coming through the gimal housing...???
I could be wrong, mine is set up like that though.
FogduckerIII is offline
