Hey you Duramax guys(you know who you are)
Found this in the May issue of Diesel Power;
"Randy's Engine and Machine has released its Gorilla Girdle for '01-09 Duramax engines. This product increases the 6.6L's block rigidity and tensional stiffness by tying all the main bearing caps together with the oil pan rail".
"Randy's engine claims its girdle will decrease friction in the main bearings by providing better overall alignment of the piston and crankshaft bores. The Gorilla Girdle applies a more even load distribution across the main bearing caps and virtually eliminates any main cap 'walk'".
http://www.randysengine.com/2009/12/...earing-girdle/
Sorry.....I took your original post as a slam on Duramax's. Like a suggestion of some inherent weakness that exists and needs to be addressed. Truth is, all current diesels produce massive torque, and would probably benefit from some strengthening.
If any diesel needed slamming it's the Powerstroke. But maybe now after three iterations, the new 6.7 Scorpion will finally be the motor Ford was hoping Navistar could build but never did.
The Dmax has only been improved through the years. Now it makes great power-397/765-and great fuel mileage. Through Banks Marine Engineering, the 800hp/900tq 5800rpm twin turbo supercharged Dmax will revolutionize performance boating. I have nothing bad to say about the Dmax. It's the best all-around diesel on the market right now.
Yes I love my Cummins, but it's not a high revver like the DMax. Without a doubt it can make big power, but it's more of a towing/hauling motor than the DMax or Powerstroke.
http://www.youtube.com/watch?v=351i-GeoYQU Withthe new stand alone software and ecm's that are coming out the duramax guys are scared.
A 900+ single charger truck is going to smoke like crazy,and it is a sled pulling truck at that. I don't think that there stand alone ecm (zues) is what they are calling it is out yet. Im pretty sure they are still working the bugs out. The new smarty is in beta testing is supposed to be pretty wild also but it is not as in depth as the zues when it come to tuning. Sorry for the high jack.
Offf topic , but i got a call from the ex whom is in the finance business , wanting me to bid on a 05 duramax she has , its a 3500 single axle , cant exactly tell from the pix but doesnt look like a full four door , but at the same time looks like an awfully big king cab. Its a Sierra , loaded with leather , 102k . Probaly cannot steal it , but will try and bid it right if i can flip and make a buck... suggestions? pros /cons of 05's
