What is the x dim
Old 04-29-2002 | 09:32 PM
phughes69's Avatar
Default What is the x dim
I keep seeing this term and don't know what it means. Where is it measured from? Is there a Y dim and a Z dim too?
phughes69 is offline
Old 04-29-2002 | 11:07 PM
puder's Avatar
speel chekk this fokker!
x dim refers to teh amoutn of money you spend getting your boat to go fatser. FYI all current research seems to show it is an infinitely large number....
But seriously its the distance between the bottom of your hull and the prop. The deeper the prop the lower the x-dim.
Pardon me, while I whip this out!
puder is offline
Old 04-30-2002 | 11:52 AM
Uncle Toys
Puder, isn't the X dimension the center of the crankshaft?
Old 04-30-2002 | 12:06 PM
EX20's Avatar
X-dimension is the distance from the bottom of the hull up to the point where the driveshaft of the sterndrive comes through the transom.
The higher the X-dim. the closer the prop is to the surface of the water.
You can effectively change the X-dim. by changing to a shorter or longer lower unit setup without having to redo the actual outdrive height.
EX20 is offline
Old 04-30-2002 | 12:23 PM
puder's Avatar
it is indeed a measure of where the prop is in relation to the hull and the surface of the water.
i was wrong on where you measure it from.
puder is offline
delsol
Drives and Lower Units
6
12-06-2007 04:24 PM
deanpp
1
08-05-2007 05:26 AM
IRONMAN
Pantera
6
09-20-2004 07:44 PM
aero-offshore
24
03-17-2004 10:23 AM
phughes69
06-05-2002 11:17 PM
