454 Mag Timing >
454 Mag Timing
454 Mag Timing
Old 06-22-2010 | 02:38 PM
Default 454 Mag Timing
I have read the the initial timing for a 454 Mag Carb should be 8 degrees. Is that at 1500 RPM's? Is there a need to check it at more RPM's.
noles5309 is offline
Old 06-22-2010 | 02:43 PM
mcollinstn's Avatar
That's at idle. 1000rpm max.Advance starts coming in at 1500 ish, so you need to stay under that for best results.
You might want to rev her up and make sure the advance is working properly, but it's usually not necessary.
Max advance should be about 32*
MC
mcollinstn is offline
Old 06-22-2010 | 07:46 PM
8 deg at 800 rpms
chuckyarus is offline
