One engine down on RPM at wot >
Old 06-28-2010 | 09:22 AM
Default One engine down on RPM at wot
Just installed my motors in new boat. Borrowed some props from a buddy. Engines run in synch fine till about 5000rpm. Then the starboard engine will pull to 5500, while the port doesnt go over about 5100. The one thats low on rpm idles fine, sounds fine. No missing, bogging, or anything.
Im guessing a fuel supply problem? Tach issue? The props are in synch on his boat.
MILD THUNDER is offline
Old 06-28-2010 | 01:31 PM
Boat was sitting for 3-4 years. Fuel tanks were about empty. Just pulled my fuel filters which were new prior to this weekend, and there was alot of crud in them. I have the fram HP canister style filters, so there was alot of crud sitting in the bottom of the filter housing.
Wonder if that could be the issue. I may pull the tank pickups and see what they look like.
Old 06-28-2010 | 06:03 PM
if pick ups are dirty I would say that engine is starving for fuel hopefuly thats the problem
firehawkcat is offline
Old 06-28-2010 | 07:36 PM
I have 5/8" lines running from pickups to filters, then to 110GPH holley mech pumps. Then 8an line from pump to carb. I think im gonna pull the pickup and sending unit and see whats going on in there. I have a feeling its got some crud in the pickup tube...
Old 06-28-2010 | 08:15 PM
Velocity Vector's Avatar
Crazy Energy
I believe there is a screen in the pickup tube
Velocity Vector is offline
Old 06-28-2010 | 08:24 PM
offthefront's Avatar
Careful at WOT ...dont lean that new motor out ....m
offthefront is offline
