Go Back  Offshoreonly.com > General Discussion > Insurance and Finance
KY LAKE PR INSURNACE CLAIM....ADJUSTER CAME BACK TODAY...Opinions??? >
Old 06-28-2010 | 02:26 PM
Default KY LAKE PR INSURNACE CLAIM....ADJUSTER CAME BACK TODAY...Opinions???
Well most of you heard I hit a submerged log while we were there and trashed a drive completely. Broke prop shaft, exploded upper gear housing, etc etc.
Insurance came back today and wants to allow me $3,379.70 to fix it. They want to replace everything with aftermarket parts. I don't understand how I insure my boat for x amount of dollars "as it sits" but they want to replace it with aftermarket foreign made parts. Does anyone have any insight or options? I almost wonder if I am better off buying a used one and putting new gears in it or if I should fork up another 2 grand and get a mercruiser built one, or get an attorney involved.
FuelinAround is offline
Old 06-28-2010 | 02:37 PM
DollaBill's Avatar
OSO OG
Dont take this the wrong way, but you're lucky they are covering it all per the "racing/sanctioned events" clause in your policy. I'd smile and take the check
DollaBill is offline
Old 06-28-2010 | 02:47 PM
insurance is a negotiation...there first offer will always be lowball hoping you suck it up and take it.
phragle is offline
Old 06-28-2010 | 02:57 PM
I figured I would need somewhere around $4500 to replace the drive. Anyone ever bought the remanned ones? Are they any good?
Old 06-28-2010 | 03:22 PM
what drive??? the only bravo knock off I know of is SEI and thats only the lower. SEI is good stuff.
phragle is offline
Old 06-28-2010 | 03:27 PM
t500hps's Avatar
21 and 42 footers
I was thinking the same thing......assumed you have Bravos and I know of no aftermarket parts for the upper.
what drive did you have?
t500hps is offline
Old 06-28-2010 | 03:53 PM
They wanted to use an aftermarket lower and then put a new casing and gears in the upper. I would prefer a whole new drive just to not ahve to worry about metal shavings and have a 2 year warranty on it. I am not very educated on outdrives and after market parts. I'm more of a motor guy but learning them. I would appreciate any input or suggestions.
Old 06-28-2010 | 04:18 PM
Your Ins Co is required to replace or repair (assuming its a covered loss) your damaged components to "equal or better" than pre loss condition.
If you have lots of hours or wear and tear on your gear, then I would say it's pretty hard to argue the use of "aftermarket" parts, unless its in "near new" condition. Always keep in mind that you have the final say in how it is repaired and who does the repair... You may however have to contribute something from your pocket to cover the added cost of the more expensive parts.
PS: You should always request that your "Field Inspector" be a Marine Surveyor (Most inspectors that are not Marine Surveyors, are not adequately educated in the marine field to make proper recommendations to your Ins Co.).
Inspector General is offline
Old 06-28-2010 | 04:57 PM
this is the lower they want to use
http://www.sterndrive.cc/mm5/merchan...ercruiserBravo
SEI's drives come standard with a three-year, fault-free warranty. This means that the unit is covered for any failure that requires the drive to be repaired or replaced. Run it without lubrication, crash into a stump, suck up some fishing line, it does not matter, the SEI drive is always covered. SEI believes this warranty is one of the best warranties ever offered for a stern drive or a outboard lower unit. Peace of mind while on the water is important, and SEI goes the extra distance to make sure that our products perform.
phragle is offline
Old 06-28-2010 | 05:32 PM
Ditto BIG Daddy
just changed a Bravo for a customer on the river who had insurance thru state farm $3700 for a new Bravo 1 with 1 year gaurantee and paid my son $140.00 for 20 mins to hang it ...Ins paid 3965.00 with shipping
Call Donnie Carter @ Offshore Perf in sunny Florida and order a drive and quit D!CKIN around,dont phuch with the adjuster too much or he'll throw 20 years of depriation on your drive
How old /what year is the broken drive ???? hours ???
Or take the 3379.00 and buy a used Bravo for 2K and you'll have some $$$$ for beer & the TITTIE Bar
