Manning trailer stinks!
Old 06-30-2010 | 08:02 PM
Default Manning trailer stinks!
I must admit I'm very unhappy with my 2007 30' Manning painted steel trailer. 2 of the brake pads froze up over the winter and broke off the other day. I went to change them and things got VERY ugly!!!!! The 4 calipers are installed at the "nine oclock" position on the axle....and this prevents me from changing the brake pads, because I can't access the lower caliper slider bolt. There is only an inch until I hit the springs, and you can't get the wrench on it...nor can you get the damn bolt OUT! The axle needs to be dropped to access that lower slider bolt. I've been told they should be installed at a 8 or 10 oclock angle.....NOT 9 oclock as mine is.
I had to cut the U bolts (due to rusty nuts etc), drop the axle, and have since rounded out the lower allen bolt in the caliper! Really pissed!!! lol I'm going to have to weld a nut on the end of the allen bolt and hopefully get it out that way..... then realign the calipers to the 8 oclock position....so in case (kill me now!) I need to change them again, it doesn't take me a month to do and don't have to drop the axles etc. etc. etc.
I must admit I'm very unhappy and totally dissatisfied with Manning and will never buy another one, nor recommend one to anyone. To top things off.....Manning tells me they don't even have Kodiak 250 pads in stock..... What a JOKE! Go MYCO next time for sure!
Has anyone had these issues??????
JayFan is offline
Old 06-30-2010 | 08:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
The pads for the 250's are the same as ones used on Cadillacs, and a couple other cars . I forget the yr and models though. Try Kodiaks website
US1 Fountain is offline
Old 06-30-2010 | 08:32 PM
You are correct..... I did get those at the autostore, but the Kodiak ones are "better" they say, and are warrantied for life.
JayFan is offline
Old 06-30-2010 | 10:58 PM
Formulabill's Avatar
I have the Kodiak parts on my Myco, but warranty for life? Good to know.
Formulabill is offline
Old 06-30-2010 | 11:31 PM
Expensive Date's Avatar
They make extractors that should remove the stripped allen.Call me by 12:00 tomorrow 609-432-9044 you are a one day zone you would have them Friday.
Expensive Date is offline
Old 07-01-2010 | 11:51 AM
I want to clarify something...... Manning trailers are GOOD solid trailers....however I'm very disappointed in the way the axle's and brake calipers are set up from the factory on my trailer, with NO WAY to access the brake pads for routine maintenance. With a few days of my labor I'm going to "correct" the issue and will have a very solid trailer.
JayFan is offline
Old 07-01-2010 | 11:54 AM
Strip Poker 388's Avatar
Rob
I have a buddy that ordered one for a 42 Tiger,the only thing was on the bottom side it didnt get enough paint in areas, they did build it in a real short time for him.
Strip Poker 388 is offline
Old 07-05-2010 | 09:40 PM
Myco Myco Myco
Top Ven is offline
Old 07-05-2010 | 09:45 PM
OL40SVX's Avatar
I've owned two used Myco's and ordered a brand new Manning for our former Cigarette. The Manning was just as good as the Myco in every way for alot less money!
OL40SVX is offline
Old 07-05-2010 | 10:30 PM
Pads warranted for life are a joke, keep inspecting those pads and rotors often. Generally it just means they are so hard they tear up the rotors first and wind up costing you more $. Softer pads seat faster, easier on rotors, and are cheaper. Randy
bustedbrick is offline
