drive swap info >
drive swap info
drive swap info
Old 07-02-2010 | 06:29 AM
Default drive swap info
I put this in drives section got nothing....whats involved with installing a newer bravo 1 on my 89 checkmate, is it a direct bolt on or ?? thanks Rob
ezstriper is offline
Old 07-02-2010 | 07:19 AM
hoozeyurdaddy's Avatar
if it has a bravo now, it should be a direct replacement I believe.
but I think it has to be a X drive not a XR, I think there is a difference in the gimble bearing.
hoozeyurdaddy is offline
Old 07-02-2010 | 07:53 AM
seafordguy's Avatar
If you're just talking about bolting the drive onto the bellhousing then yes - no problem.
You can't bolt an XR onto a normal style Bravo Gimbal.
seafordguy is offline
Old 07-02-2010 | 09:14 AM
so the later model are a direct swap...thats what I wanted to know..now which are the best to try to run down ? thanks again..Rob
Old 07-02-2010 | 10:58 AM
Don't forget if its an older bravo gimbel with no self oiler set-up then a newer bravo drive will not just bolt up since the new bravo drives have the self oiler set-up and fitting on the drive that fits into the gimbel.
Erik
crapr6 is offline
Old 07-02-2010 | 11:05 AM
mine does have the remote oil resevoir, not sure if it was updated or came that way ?? thanks !
Old 07-04-2010 | 11:11 AM
AIR TIME's Avatar
go to a b1x drive , its got the steel tower worth the few extra bucks.
AIR TIME is offline
Old 07-04-2010 | 11:27 AM
tony davis's Avatar
Erm, yes you can!
tony davis is offline
