Wanted Pair of Drives to Suit 370Hp Diesels
I am looking for a pair of drives to suit 370Hp Yanmar diesels the boat weight is about 5000Kg laden and it is 34 ft long I would consider anything Z Drives Surface Drives Jet Drives etc it just needs to be cheap thanks
As they say, good things aren't cheap and cheap things aren't good.
I can tell you that a Bravo style drive will not last long with that power and weight combination.
www.arnesonmarine.com
Arneson Surface Drives www.arneson-industries.com
I have a pair of Tri-Max surface drives that are fresh. You would need drop boxes and a rudder so this would not fall into the cheap catagory but they are fast and durable. I have some Weissman drop boxes also available, but they would need significant changes for the deisel application.
