Fuel Regulator Placement?? >
Old 07-08-2010 | 02:50 PM
Default Fuel Regulator Placement??
Almost done building 496. I will be running a Mr. Gasket 130 gph marine mech fuel pump. Machine shop is recommending fuel log then regulator after carb at end of log then return line back to tank. This completely threw me for a loop as I've learned from here that the reg should go closest point before carb. Which way is best? How does the first method reduce pressure at carb if reg is set up after it?
ramos45 is offline
Old 07-08-2010 | 10:14 PM
offthefront's Avatar
I'm running the Holley Marine 110GPH .... runs 7-8 lbs no regulator .....runs perfect ... 600hp 496's
no regulator needed ....
http://holley.com/712-454-11.asp
offthefront is offline
Old 07-08-2010 | 10:46 PM
That's the way fuel injection is setup. The regulator holds the pressure in the line at whatever it's set at and then bleeds the excess back to the tank.This way you will need a return line going back to the tank. I would do it the way you are thinking it should be if I were to run a regulator. I run the Holley Marine like offthefront is using. Works great with no need for a regulator. 505 cu.in 600hp
http://www.summitracing.com/parts/HLY-712-454-1/
picklenjim is offline
Old 07-08-2010 | 11:24 PM
Thank you both for your responses. I've spent so much time searching this site and the net to figure out whether or not I needed a regulated pump. Every builder I spoke to even people at Summit, CP, and carb shops recommended the 130 which needs regulator. They all said better to overkill than risk lean. I already have the 130 pump on the way. If I get a return style reg I'll tee it into the overflow line. I really don't feel the need to tap a new hole in the tank.
ramos45 is offline
Old 07-09-2010 | 01:19 AM
Tee'in into to the overflow line sounds kind of scary to me. If you fill your tank you may end up pumping gasoline overboard out that line. Remember at times there will be quite a flow going back to the tank.
I do remember one time seeing a fuel level sending unit that had a fitting made on it to connect a return line to. Just can't remember where. If I come across it I'll post it.
Here's one that tee's into the fuel fill hose.http://www.cpperformance.com/c-500-f...s-returns.aspx
Old 07-09-2010 | 04:05 AM
I dont think you'll need a return line for that fuel pump using the right regulator ...that pump only rated at 9lbs and you'll need 7-8lbs ....check though ..m
Old 07-09-2010 | 06:10 AM
useless....
ezstriper is offline
Old 07-09-2010 | 08:41 AM
Any idea where to find one of these for 1 1/2" fuel fill line?
Pure Energy is offline
Old 07-09-2010 | 10:52 AM
Originally Posted by ezstriper
useless....
What a waste of time...
ramos45 is offline
Old 07-09-2010 | 10:56 AM
Fill hose makes more sense, don't know what I was thinking. IF, I need a reg I haven't fully decided on a return style or deadhead. I'm still researching. Everything I find pretty much says deadheading a mech pump doesn't cause any issues as oppose to a elec pump.
ramos45 is offline
