Radial or Bias ply trailer tires >
Old 05-01-2002 | 12:47 PM
NW_Jim's Avatar
Default Radial or Bias ply trailer tires
What do you have on your trailer? I'm just learning about trailer tires and noticed they have an ST designator for "Special Trailer"
I also found out the tires I have on the trailer are only rated for a grand total of 6000 lbs. I estimate the weight soaking wet to be about 13,500 lbs.
I figured it out and it needs ST22575D15's with a #2540 load capacity ea. Here's the problem, the tires that are on there are only 14" with a 5 on 4.5 bolt pattern. The tire shops will not mount the 15" tires I need on the 5 X 4.5 rims stating that they will not handle the weight. Do I have to change my hubs now?
Thanks for the help.
NW_Jim is offline
Old 05-01-2002 | 01:44 PM
NW_Jim's Avatar
ttt
NW_Jim is offline
Old 05-01-2002 | 02:00 PM
What size axles are they ? Probably 3500 lbs, Could be 5200lbs ?? The five hole hub is OK . The hub is usualy not the weak point .The axle spindle , the axle shaft , or the wheel and tire are the consern .But if you had 14" wheels and want 15" tires ,you need 15" wheels . If you have 15" wheels for the new tires ,They have a rating on them .Or they should . If they are too light ,you may need heavier rated wheels . What boat and trailer do you have ? What is the trailer rated for ? HOw many axels ?(3 ,I hope !!). The biggest problem with light wheels and tires is turning on hard ground or backing down a steep ramp . It puts extreme pressure on the tires and wheels and can rip the tire off the wheel or rip the center of the wheel out !! I have seen it happen many times . Let me know if I can be of more help .I am in the trailer and towing buisness . JOE
boot is offline
Old 05-01-2002 | 02:02 PM
Oh and yes , I do use the ST radials on all our trailers .
boot is offline
Old 05-01-2002 | 04:35 PM
NW_Jim's Avatar
Joe, thanks for the response.
I don't know what the axles are rated at. Is that marked on the axle somewhere?
I know I will need 15" rims. I have a 1987 35' Cafe Racer and a Vanguard trailer.
I figured the boat weighs 9500 lbs, full load of fuel about 1500 lbs, misc, around 300 lbs, and trailer should be about 2000 lbs for a grand total of about 13,300 lbs. Divide that by 6, (yes it's a triple axle) and you have 2216 lbs per wheel. The 15 X 6" with 5 on 4.5 bolt pattern are only rated at 2150#. The ST22575D15 tire is rated at 2540#. If I go this route, I will be about 400 lbs. over weight for the wheels. Do you think this is OK? I guess the first thing to do is find out what the axles are rated at. Again I appreciate the info.
NW_Jim is offline
Old 05-01-2002 | 04:37 PM
NW_Jim's Avatar
Thanks Troutly, I'm suprised they put radial Light Truck tires on that trailer.
NW_Jim is offline
Old 05-01-2002 | 04:38 PM
CigDaze's Avatar
Don't forget,
I think the standard states something like a twin axle trailer should be able to run with one flat, and a trip with two flats...I think I read that somewhere in an old Trailer Boats Mag.
CigDaze is offline
Old 05-01-2002 | 04:52 PM
NW_Jim's Avatar
Sure....Somebody has to come along and throw a wrench in my spokes...
I may be looking for a new trailer before I'm done here. Should get one like Sean's.
NW_Jim is offline
Old 05-01-2002 | 04:53 PM
CigDaze's Avatar
Hey, there's always got to be a spoiler at every party!
CigDaze is offline
Old 05-01-2002 | 04:59 PM
Tonto's Avatar
Jim
I use the Goodyear Workhorse PERIOD on my trailers. I hate to say it but it sounds like you might be a little light in the trailer dept. There should be a plate towards the front of the trailer that tells weight capacity of the trailer and each axle. Good luck
Robert
Tonto is offline
