Sea Water Pump rebuild question >
Old 07-13-2010 | 04:34 PM
Default Sea Water Pump rebuild question
Is the bearings and seals hard to change in this set up?
Looks like I need to replace part numbers 15-16 and 19 shown below.
http://www.mercruiserparts.com/Show_...SEA+WATER+PUMP
Shah Mat is offline
Old 07-13-2010 | 04:58 PM
I looked at doing the same thing, almost the same price with in a $100. Nothing beats new.
Greenkeeper is offline
Old 07-13-2010 | 07:47 PM
Default Fixx
its a piece of cake! make sure you use a press tho..
FIXX is offline
Old 07-13-2010 | 07:53 PM
seafordguy's Avatar
Are you sure that is the problem? Have you pulled it apart yet?
Only reason I ask is because I had one lock up the other day to the point the enginen wouldn't turn over - I assumed I had burned the bearings out of it and when I pulled it apart I had torn up the impellor which had lodged and prevented the thing from turning over. 50 dollar impellor kit and 20 minutes and I was back up and running..
seafordguy is offline
Old 07-13-2010 | 08:03 PM
Here you go, very well written with pictures
http://www.offshoreonly.com/forums/d...fuel-pump.html
1BIGJIM is offline
Old 07-14-2010 | 04:12 AM
The seal is bad between the impeller and the bearings.
Shah Mat is offline
Old 07-14-2010 | 09:38 AM
I found those bearings and seals at my local auto parts supply, but that housing has a fuel pump mount and mine does not. I wonder if it uses the same bearings and seals??
Shah Mat is offline
Old 07-15-2010 | 03:33 PM
I don't think so....the one that runs the fuel pump is a POS and nothing but $$$ problems..my .02 !!!
ezstriper is offline
