*****Intake manifold question********* >
Old 07-13-2010 | 07:13 PM
Default *****Intake manifold question*********
Got a Volvo Penta 5.7l GL. Just pulled off the Intake manifold. It was an old Holley street dominator 300-1. Def the wrong intake for that motor since the 4 inner holes were drilled out to accomodate the the different angled bolts. (86-95 chevy small block, non-vortec) Question is.... If i am only running in fresh water, can i put another aluminum intake on? I have cast iron heads. I was told both yes and no. Tried looking for a cast manifold 4bbl and they are now obsolete. Also cant find an aluminum with brass inserts. Any help/advice would be appreciated. thanks
rrspear23 is offline
Old 07-13-2010 | 07:45 PM
Default Fixx
i have been running a edelbrock air gap on mine with out the brass inserts for the last 10 years,,,the intake passages are still mint..i also have a lifter valley baffle to keep the intake cool from the oil splashing on the bottom..
FIXX is offline
Old 07-14-2010 | 08:30 AM
just get a performer style intake for vortec heads and roll on
ezstriper is offline
Old 07-14-2010 | 09:33 AM
Default Fixx
he has a non vortec engine so that intake wont fit at all..what he is referring to is the 4 inner bolts, the angle is different then the earlier designed Chevy heads..
FIXX is offline
Old 07-14-2010 | 12:00 PM
I agree with Mrfixxall.....run the edelbrock air gap. Its a nice intake for what your doing.
tinman565 is offline
Old 07-14-2010 | 03:56 PM
I've been using aluminum without inserts for years in salt water. What I do is use epoxy primer and paint with a brush in the water ports after a complete cleaning before installing a new intake(won't work with a used manifold as there is aready corrosion) seems to fight of the corrosion pretty well.
doggiedave is offline
Old 07-15-2010 | 07:14 AM
thought he said intake was a non vortec ?? holley 300-1..std heads
Old 07-16-2010 | 08:06 AM
your right. I did say that. When i pulled the manifold off the 2 center bolt holes on both sides were drilled out. Check it out. posted pics on photobucket. I heard there is alot of expanding with aluminum intakes with cast iron heads. Makes them leak. Still looking for a cast iron manifold for this.
http://s916.photobucket.com/albums/ad5/rrspear23/
Old 07-16-2010 | 08:00 PM
Hmmmm....97% of the guys on here must have leaks...cause most of us run aluminum manifolds and iron heads. But what do we know ?
