Vacuum Pump
Old 07-16-2010 | 09:42 PM
Default Vacuum Pump
Alright this topic has been covered before. How many of you use vacuum pumps? Did you see a HP increase? Are low tension rings required? What PSI do you run (10-15)? Just looking for a couple more MPH for next year and reduce blowby.
jeffswav is offline
Old 07-19-2010 | 08:50 AM
ttt Anyone, I know somone has to be using one.
jeffswav is offline
Old 07-19-2010 | 12:38 PM
I used to run them on all of my drag motors. Yes, you do need low tension rings and they were good for 15-30hp on various motors. Can't say I've ever seen on in a boat though.
Griswald is offline
Old 07-19-2010 | 12:43 PM
I went through some old post and found a few guys using them. Some said big gains (30HP), others said no gain. Just wanted to see if anyone else had tried it. It was also stated by a few that low tension rings were not needed, but the pressure is limited.
jeffswav is offline
Old 07-20-2010 | 06:15 AM
I run one in my top sportsman drag race engines, but in boat engines in the rpm we run I would say 0 h/p gain..unless you run a elec one takes h/p to turn the pump..at least in a full race type setup...Rob
ezstriper is offline
Old 07-20-2010 | 12:11 PM
The problems I hear are burning up the piston pin in an endurance type application, the vaccum pump kills a lot of the oil flying around in the crankcase
SHAWN DAVIS is offline
Old 07-20-2010 | 05:03 PM
This is a performance/pleasure boat, about 90% of the time is spent at 3K RPM maybe 10% is running hard. Just looking to tweek out a few more MPH without any major changes. Maybe not even for this winter but just somthing to plan for. The engine is running perfect and I do not want to crack it open. A Stellings box raised 2" would be cool but a bunch of money to get a few MPH.
jeffswav is offline
Old 07-21-2010 | 07:17 AM
don't waste your $$ there
Old 07-21-2010 | 07:42 AM
phughes69's Avatar
I think the HP gain is from running the low tension rings and a little less crankcase pressure. You probably would not see enough HP gains if you were to use std tension rings to justify the cost of the pmp and all the other associated hardware.
phughes69 is offline
Old 07-21-2010 | 08:58 AM
Thanks for the input guys.
I will most likley put this one on the shelf and look in other places to upgrade.
jeffswav is offline
