Stereo
Old 07-18-2010 | 10:27 PM
Default Stereo
My amp on my stereo cuts in and out when playing the radio. I think its not drawing a enough power from the battery not sure what to do.
nooch315 is offline
Old 07-19-2010 | 02:07 AM
Most likely the power and ground wires for the amp are not large enough gauge wire.
Griff is offline
Old 07-19-2010 | 10:51 AM
Thanks I'll check that out hopefully thats it.
nooch315 is offline
Old 07-19-2010 | 11:33 AM
88Fount33's Avatar
Beak botr
Had a similar problem a while back, turns out the battery (when engine not running) was bad, did not have enough voltage to run amp (amp wanted 12.1 or .2, and battery was only good for 12, amp would not "cut in". Funny thing was that the battery would start the engine and when running the amp was fine as voltage was 13.8 or so.
88Fount33 is offline
Old 07-19-2010 | 01:36 PM
obnoxus's Avatar
Charter Member #1171
Not enough battery,,,,, the amp is clipping.
Try an Optima or something similar
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 07-20-2010 | 01:17 AM
Thanks guys makes total sense. I'm not sure what an Optima is though.
nooch315 is offline
Old 07-20-2010 | 01:19 AM
Nevemind a Battery
nooch315 is offline
Old 07-20-2010 | 07:11 AM
Audiofn's Avatar
Charter Member #232
More then likely your voltage is dropping to low. Put a meter on your battery and test that then put it at the power terminals on the amp. If there is any voltage difference you have bad wires. If the battery idle is lower then 12 volts you have a bad battery.
Put your best foot forward!
Audiofn is offline
Old 07-20-2010 | 07:14 AM
Audiofn's Avatar
Charter Member #232
PS. I would get the Sears high end batteries before the Optima any day of the week. They are made by Johnson and are some of the best batteries you can buy. They are about the same as the Stinger batteries that are also fantastic. They have a MUCH lower failure rate then the optimas.
Audiofn is offline
Old 07-20-2010 | 09:05 AM
X2
I never sell optimas to customers, they are garbage, HORRIBLE recovery rates. I use Interstate SRM-29 batteries for stereo power, they have great reserve and excellent recovery rate and they are in-expensive. I outplay everyone on the water all the time. Also make sure your ground is good I.E. tight and the correct size, poor grounding tends to be the #1 failure in car/marine audio, its often overlooked by many shops.
stopdropanroll is offline
