Help with Carb
Old 07-19-2010 | 11:16 AM
Default Help with Carb
I have a stock 454 mag with a Weber/Carter AFB/Edelbrock carb. After I run for a while then stop it is hard to start, like it is not getting fuel. I have heard that these style carbs have had problems with the fuel boiling out of the bowls. Has anyone had any issues with this and how to fix. Almost ready to buy a new carb.
noles5309 is offline
Old 07-19-2010 | 11:26 AM
I never had a problem with my Weber carb after it warmed up. It would leak the fuel out of the bowls after sitting for a week or so and cold starts sucked.
Griff is offline
Old 07-19-2010 | 11:36 AM
just started a year ago. never had problems before
Old 07-19-2010 | 01:59 PM
Try a rebuild kit first
dslbrnr is offline
Old 07-19-2010 | 02:09 PM
You can probably buy a used big block Qjet cheap, that solved the problem for the ones I've worked on. The throttle linkage will hook up OK. Your manifold is probably a spreadbore with an adapter, so just toss the adapter. You'll need to make or buy a fuel line. The choke linkage will even work if you put a bend in the rod.
rdoactive is offline
Old 07-19-2010 | 03:02 PM
The carb has been rebuilt and didnt make any difference. I found a refurbisehd Holley online, but dont know how to tell if it will match up with what i have
Old 07-20-2010 | 01:34 AM
The stock magnum intake will fit a Weber, Qjet or Holley carb. Its is drilled for both spreadbore and squarebore carbs. If you switch to a Holley, then you will need about $50 worth of parts to connect the throttle cable linkage.
Griff is offline
