28' what props?
So my boat Consistantly runs 81-82 all day long. I'm banging off the rev limiter. Running 28 labbed bravo 1's from throttle up. Should also note that the props are "river props" and chewed up pretty bad. Question is....what props should I switch to? Rpms on analog gauges seem to show around 5200 rpm.
Hi V/c i am running the same boat as you 2001 28 pantera 496HO with 28 15 bravo1 props not took boat to the limit yet but i will on monday sea has not been flat enough for top speed as soon as i no i will let you no wot speed and rpm, When i talked to Jo some months ago about the boat he did tell me with the setup we have 81-83 mph is wot we should get he allso said they would pull hard fome 60 -80 .,and he is right on the button acording to your speed .i would like to no if anyone has done better with diffrent props regards paul from uk
Talk to the guys at Throttle Up (since they did the set), and maybe they can tighten up those 28's a touch for ya and get you off the limiters. Since they're dinged up already it might not be that hard to loose a couple hundred RPM's. (The nicks and dings will affect slip.)
