3 to 4 blade help >
3 to 4 blade help
3 to 4 blade help
Old 07-28-2010 | 02:49 PM
Default 3 to 4 blade help
I am running 3 Blade Bravo 27P props. I would like to go to 4 blade. What direction should I take???? Do you need to go up or down when going from 3 to 4 blade??? Thanks Chris
doral1 is offline
Old 07-28-2010 | 03:27 PM
You have 3 Blade Bravo 27P.
You have to go down in pitch to keep the same RPM when adding 1 blade.
Try a 4 Blade 25 pitch to regain your possible 400rpm loss.
You can loose up to 400rpm by adding one blade and keeping the same pitch.
Every pitch you decrease will increase your rpm 150-200rpm.
I lost 400rpm by going from a 4 blade to a 5.
UrbanDisturbance is offline
Old 07-28-2010 | 07:50 PM
here my numbers=GPS and smartcraft digital rpm.best
mirage+ 23 66.4 at 5050
bravo1 22 64.5 at 5150 hit the rev limiter.
but i realy dont know nothing about a bravo 3 blade???
zx14k is offline
Old 07-28-2010 | 09:22 PM
onesickpantera's Avatar
There is no Bravo 3 blade. A Bravo 24 would probably be your best bet as it's actually closer to a 23. It will probably run 4800 give or take. There's lots of other 4-blade props out there.
Is there a reason you want to switch to a 4-blade?
onesickpantera is offline
Old 07-28-2010 | 09:27 PM
I have a mercury lab 24 for sale
http://www.offshoreonly.com/forums/s...egt-setup.html
goebel1 is offline
