Alpha 1 to Bravo 1 upgrade >
Old 08-02-2010 | 11:23 AM
Default Alpha 1 to Bravo 1 upgrade
offshoreboat1
1987 Chris Craft Stinger 260 Alpha 1 to Bravo 1 upgrade
Hi,I am going to replace my Alpha One"s with Bravo one"s on my CC Stinger ,
Should I replace my engiinecouplers also? Or can I reuse the Alpha Couplers?
Thanks for help
offshoreboat1 is offline
Old 08-02-2010 | 07:30 PM
are the couplers in good shape
firehawkcat is offline
Old 08-03-2010 | 08:55 AM
hoozeyurdaddy's Avatar
bravo's use a larger coupler, alpha's use a small one, you should change them or they will become the weak link.
hoozeyurdaddy is offline
Old 08-03-2010 | 09:10 AM
Do you need the bravo drive? Are you breaking Alpha's? Because in a straight up swap, you will lose a few mph's going from an Alpha to a Bravo.
macjazzy is offline
Old 09-01-2010 | 10:56 AM
Default sorry for late reply
Thanks for replys.
Couplers are in A1 condition,
just have bad gimbal housings on Alpha ones,and a good deal on the Bravos.
Replaced the stock 260 Mercs with 383 strokers,so think Alphas wont hold,as I read overhere.
Roland
Old 09-01-2010 | 10:24 PM
i have a procharged 350 magnum carbed with some work done 6 psi on my alpha drive just easy out of the hole and no wave jumping. 2 years and going strong runs mid 70's on my scarab 22.
boosted22 is offline
Old 09-02-2010 | 08:22 AM
Well, that's 2 years you have had to save your money, because you will need it at some point, alpha's just don't do well with high HP and Torque. but keep up what your doing, it seems to be working.
Old 09-02-2010 | 02:44 PM
Too Stroked's Avatar
The other big difference here is weight. You have a relatively light boat compared to the OP. When you add more HP, more torque - and a heavy hull - an Alpha won't last very long.
Too Stroked is offline
Old 09-03-2010 | 01:11 PM
Heavy boat + stroker + alpha = BOOM!
Mine lasted four trips
Fastereddie is offline
Old 09-04-2010 | 10:45 AM
If you are asking what you will need. Here is the list.
Bravo Coupler
Bravo Bell Housing
Bravo inner transom plate
Bravo Gimble
Bravo Trim Rams
Bravo Drive
I just did the alpha to bravo conversion on my 242 formula and nothing but the trim pump on the alpha will work. Unless you have time to find deals expect to spend at least $2000-2500 for everything.
endeavour32 is offline
