Removing Bravo III with DTS >
Old 08-03-2010 | 09:25 AM
DORaymond's Avatar
Default Removing Bravo III with DTS
Do I have to manually shift the drive into forward via the cable in the bilge so that the claw disengages when I pull the drive? I believe that if I shift into forward with the ignition on, and then turn the ignition off, the computer will put it back into neutral and I won't be able to disconnect the drive.
DORaymond is offline
Old 08-03-2010 | 09:33 AM
Knot 4 Me's Avatar
You do not shift Bravo Drives into forward to remove them as you would an Alpha drive.
Knot 4 Me is offline
