1,800 HP, single engine, what hull? >
Old 08-12-2010 | 02:20 PM
Default 1,800 HP, single engine, what hull?
Hello everyone, first post here and I hope to get some good advice on this.......
If you had 1,800 HP going into a hull with a single engine, what hull would it be? Not looking for brand new but used. Every boat over 27-28' goes to twins from what I can see.
V-hull or cat?
What drive would you want?
This would be for lake use only.
Thanks for any input, H V
Hallett Vector is offline
Old 08-12-2010 | 02:23 PM
There are a few 32 Sunsation singles. Personally 1800hp into a single engine boat is way overkill and a death trap IMO.
Griff is offline
Old 08-12-2010 | 02:27 PM
Steve 1's Avatar
V-hull or cat?
Properly designed Cat.
One of Pats Hammerhead drives.
Steve 1 is offline
Old 08-12-2010 | 02:28 PM
a jet drive... I cant see a prop big enough to take advantage of 1800 hp working on a single vee without put it on its side the first time you hit the gas....
phragle is offline
Old 08-12-2010 | 02:33 PM
Caincando1's Avatar
A big Velocity with a splitter gear box into two big outdrives. I know Velocity has done some bigger singles. I also know that a ski boat was built with a splitter (not sure on the correct term) to put one big single into two outdrives.
Caincando1 is offline
Old 08-12-2010 | 02:35 PM
Thanks for the 3 responses!! That was faster than I thought it would be.
Is anyone running big HP in a cat around 30' or so?
H V
Old 08-12-2010 | 02:38 PM
Steve 1,
I did a Google search and a search here for hammerhead drive and came up with nothing???
H V
Old 08-12-2010 | 02:41 PM
Steve 1's Avatar
Steve 1,
H V
Sorry Pat Weismann http://www.weismann.net/Press%20Page...annDuoProp.htm
Steve 1 is offline
Old 08-12-2010 | 02:53 PM
32 Activator.
TexomaPowerboater is offline
Check300 is running a 30ft Checkmate, a single with HP in that nieghborhood. Runs a #6 drive set quite deep. The boat handles well.
Dan Adams is offline
