Remote mercruiser oil filter mounting >
Old 08-16-2010 | 02:23 PM
Default Remote mercruiser oil filter mounting
I recently purchased some sst mercruiser risers to delete the rust cast iron mercruiser risers. However, this prevents mounting of the oil filter unless I use a spacer on a long stud on the port side of each motor. I'd rather avoid this and mount the oil filter to the transom. Is there a good billet alternative out there to do this. It would make the engine compartment cleaner looking.
Rexx is offline
Old 08-16-2010 | 03:18 PM
Just get a piece of 1.5-2" inch aluminum angle iron and cut it to size and drill the holes. I used actual steel and painted it and it worked fine as well, but in a salt water environment, I would use aluminum.
Griff is offline
Old 08-16-2010 | 07:36 PM
In was thinking to do that, but wondered if something out there already existed before busting out my hacksaw. I would expect this to be a $15 item in Hardin marine! It'll cost me $15 in raw material at home depot. Seriously, aluminum is priced like gold at home depot, what gives?... My wallet!!
Rexx is offline
Old 08-16-2010 | 08:39 PM
$15 from Hardin..........LOL. It'd probably be $115
Aluminum, as well as most other metals is way up in price.
You could order it precut here in the exact size and thickness that you want. http://www.midweststeelsupply.com/store/home
Griff is offline
Old 08-16-2010 | 09:00 PM
Cool
Sweet!! Looks like a promising place. I haven't been able to get good raw materials since moving to s. Fl from IL.
Rexx is offline
Old 08-17-2010 | 11:51 AM
Smile
is aluminum angle iron a new alloy
tunertech is offline
Old 08-17-2010 | 08:02 PM
Yep, they have a lot of stuff. I ordered some aluminum plate from them and they had the lowest price I could find online.
Yep, its a new top secret special metal. LOL
I just wanted to make sure he knew what I was referring too
Griff is offline
Old 08-18-2010 | 08:15 PM
I used this place:
http://www.speedymetals.com/
They were very accurate with the cut to length stuff I wanted.
Home Depot is just a bad place to buy metal high prices and last time I was there, no alloy traceability. Thank you internet or else I'd be screwed out here.
Randy
bustedbrick is offline
Old 08-19-2010 | 10:10 AM
Wow...checked out the site, are their prices really that cheap?
Rexx is offline
Old 08-20-2010 | 02:57 PM
I had to move my filter as well. I also fabed a bracket and went with paint (actually powder coat but I had other stuff being done so I through it in with that stuff). I know when I raised mine to clear the new exhaust, my lines were too short. I had to tig a few inches into the stock oil line. I would have just made a new line but ran into a problem on the stock oil cooler fitting. The stock oil cooler had a double flared fitting and I couldn’t get a single flare to seal on the cooler?
Griff...did you have that issue?
baja_brian is offline
