Anyone tow with a lowered 2wd dually? >
Old 08-18-2010 | 10:33 PM
Default Anyone tow with a lowered 2wd dually?
1980 chevy crew cab....hopped up 454, all black and chrome ex show truck....the thing is supposed to be lowered 12".....Im wondering if anyone who owns a lowered 2wd dually ever scrapes coming out of ramps?
pullmytrigger is offline
Old 08-18-2010 | 11:14 PM
Never had a lowered truck, but I imagine you'll have trouble w/anything other than a 10' aluminum boat.
publius is offline
Old 08-19-2010 | 12:34 AM
It wouldn't surprise me if the truck 'crowned' trying to get over the hump. If it's an air-activated setup you shouldn't have that problem...
Catmando is offline
Old 08-19-2010 | 06:51 AM
BUIZILLA's Avatar
instigator
12" lowered when it only had 8" ground clearance to begin with???
BUIZILLA is offline
Old 08-19-2010 | 07:28 AM
They must have dug a trench to get it that low !!!
cat boat racer is offline
Old 08-19-2010 | 08:42 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
The only way to do it would be with a full airbag suspension, and then you have virtually no towing capacity. It's a loosing proposition all around.
You remove suspension travel when you lower a vehicle. Usually, the lowest portion of the vehicle determining ground clearance when stock is the front A-arms/suspension or the differential pumpkins.
Sydwayz is offline
Old 08-19-2010 | 09:18 AM
Get a normal truck!
UrbanDisturbance is offline
Old 08-19-2010 | 10:19 AM
Ted G's Avatar
Offshoredrillin tows his Tiger with a lowered dually, I don't think his is as radical as that though.
www.cbpba.com
Ted G is offline
Old 08-19-2010 | 03:41 PM
12" drop is excessive for a tow rig by far! A full bagged set up will handle the weight if equiped with the right bags. There are a few around here that have air bar suspensions that handle 20,000lbs and the ride height can be adjusted to make the truck level.
I have a lowered 2010 GMC 1500 with helper bags and it tows great im not pulling 15,000lbs but i can fill the bags to level me back out. Depending on how they lowered the truck will dictate how much suspension travel you have. Either way 12" of drop seems like they both body dropped a few inches as well as suspension dropped it.
It would be a very comfortable rig to tow with and it would wear you out on the trip to the lake.
murdered6.2 is offline
Old 08-19-2010 | 05:13 PM
Check the notches for stress cracks
andychb is offline
