Stainless Marine Gen III 5" tailpipe fitting specs pls?
Dear OSO members,
Does anyone have dimensions or fitting specs on the Stainless Marine Gen 3 with 5" stainless tailpipe? I emailed stainless marine but no reply yet. Wonder if the tailpipe angle will match the stock transom exhaust holes. Original motor was 7.4mpi with capt choice silencer . tks
If the set you got was made to be a direct replacement for a stock merc setup then yes they'll fit. if your trying to use tailpipes that came from another setup like a trs with a tranny then you be buying a hole saw.
