What causes my dip stick to pop out????
I am working the bugs out of a Paul Phaff engine swap in my Force Offshore. The engine still has a minor ignition issue and runs a little rough (cuts out and/or on/off at speed), so I will be replacing the thunderbolt distributor with an MSD setup. Other than that, everything is pretty sound, no backfires to speak of.
The problem I have is the dip stick will pop up about 3 or 4 inches after a full throttle run and mist oil everywhere. Is this a sign of bigger problems?? Or am I not venting the crankcase properly?? Any advice??
your getting some major blow by in the crankcase from the cylinder there. I had the same problem a few yrs ago with a turbocharged import i had (130,000 miles though). dipstick popping up and blowing oil all over the engine bay. within 6 months, i had half compression on two cyls. and you just had this rebuilt?
could be the venting ,what breather/PVC etc do ya have .
Mine would do it, I put a puke take on it with #12 lines and no more problems.
I seen some engine builders put a spring to hold it ,band-aid it
Nothing going to the air cleaner at this point. The valve covers both have breathers built in, I figured they were good enough to vent the engine. Where should I put a PVC on the engine?? There is no provision for one in the valve covers.
a leak down test would tell you alot more than a compression test sounds to me like the rings are not seated correctly or the vents are plugged up better breathers will probably take care of the problem
www.bajaboatowners.com
another thought ,to much oil maybe aerating it and building crack case pressure.Does it have a aftermarket oil pan /dip stick,are ya sure of the oil level?
What size/kind on breather ya got? if its blowing out the dip stick it should be blowing oil out the breathers also.
ya don't have to have a PVC.
do what Ebay Ed said ,do a leak down, that should show a indication of blow by.
I agree on the leakdown test...tell for sure...50 hrs does not mean s#$t can blow one up in 2 or less...if the leakdown comes out ok a PCV will help..converted all my engines over to it like HP500 runs, keeps the engine cleaner..they run the valve in the intake base behind the carb..I used the valve covers on all of mine...
