What would make Carb overflow when hot? >
Old 09-01-2010 | 12:54 PM
Default What would make Carb overflow when hot?
Its an HP500 carb, we have already rebuilt it, set the float levels multiple times and it keeps doing same thing,
once you have been out running for a while and idle down to dock it will sputter and be way rich, as you look down carb bores you can actually see fuel trickling out of tubes. Makes it a scary propisition to dock.
When its cold it does not do this, idles perfect , nice 13.9-14.1 AFR , no fuel dripping.
Driving me bonkers..
Its sitting on a Ebrock Victor Jr with no heat passges so intake stays relatively cool.
HTRDLNCN is offline
Old 09-01-2010 | 01:36 PM
Replace the needle and seat. If it is a brass float be sure it has no fluid inside.
Boat1 is offline
Old 09-01-2010 | 06:44 PM
blue thunder's Avatar
How much fuel pressure when this happens?
blue thunder is offline
Old 09-01-2010 | 08:22 PM
I had a Holley 800 do the same thing this spring. You could look down it and see gas pouring out. I just took the one bowl off cleaned it, set the level while the engine was running and never another issue.
1BIGJIM is offline
Old 09-01-2010 | 09:00 PM
Check the floats to make sure they are not filled with fuel.Also have you replaced the fuel pump with a higher volume. Those needle an seat cant take any more than 7 lbs .
excalibur82 is offline
Old 09-01-2010 | 09:23 PM
Yep what he said !!! Even if they look good , which they will replace them .
Jeff P31 is offline
Old 09-02-2010 | 07:58 PM
not the vent tubes, it leaks out the venturi where fuel normally comes out when it is running.
Stock fuel pump.
Only does it after it warms up so if it is the float wouldnt it do it all the time?
Thanks!!
HTRDLNCN is offline
Old 09-02-2010 | 08:35 PM
Thunderstruck's Avatar
Bad Power valve? Idle not adjusted properly so that low idle vacuum lets the power valve open??
Long time cult member.
Thunderstruck is offline
Old 09-02-2010 | 09:08 PM
replaced power valve
good idle until it heats up and good vacuum.
Frustrating.
HTRDLNCN is offline
Old 09-02-2010 | 09:40 PM
Try calling the Holley tech line
BenPerfected is offline
